AF 33
AF 33
AF-33 has been re-formulated to be a harder more durable finish for all types of vessels – from workboats to daysailers. Its formula is effective in performance for a single season. Lower cost saves money.
....also Hart ist es wirklich, ansonsten hilft keine Formel da muss schon was rein.Stichworte: -
alu (4)
aluminium (4)
aluminiumboot (4)
antifouling (33)
antifouling erneuern (6)
antifouling gfk-boot (6)
beschichtung (4)
entfernen (4)
epoxy (4)
erstanstrich (3)
gelshield (4)
gfk (16)
grundierung (5)
kiel (5)
korrosionsschutz (4)
neu (4)
neuaufbau (8)
neubeschichtung (4)
osmose (8)
refit (4)
segelboot (5)
stahl (9)
stahlrumpf (6)
stahlyacht (5)
unterwasserschiff (14)
