Cukote Plus
  • Cukote Plus
    Cukote’s high loading of cuprous oxide makes this formulation a top performer, even in the most severe fouling areas. As an ablative, self-polishing coating, there is no buildup ofpaint over time. Your hull's underwater surface remains smooth and clean. Cukote copolymer can also withstand removal from water without affecting itsantifouling properties.
    Ein einfaches Kupferoxydantifouling, erodierend, 12 Monate Standzeit, Bewuchschutzdauer 1 Saison, so wie auch die andere 245 Anbieter oder Umfüller.
