Biocop Plus
  • Biocop Plus
    Islands 77 Plus was developed as an alternative to tin-based antifouling paints to protect against the harshest marine environments. Using the newest biocide technology, a revolutionary polymer binder system produces an engineered biocide release that leaves no harmful effects on the environment. The result is a multi-season self-polishingpaint that provides equivalent protection to tin-based formulas.
    Ein erodierendes Hartantifouling einfachster Herstellung, damit lässt sich kein Bewuchs einer Seepocke oder Miesmuschel abwehren. Für den Trinkwasserspeicher wie ich immer sage würde es für einige Zeit reichen.
