SeaForce 90
  • SeaForce 90
    SeaForce 90
    self-polishing antifouling based on copolymer binders
    drydocking interval / service life time: 60 months
    Antifouling agent / Biocides
    trade name / compound group: copper, zinc
    chem. name: dicopper oxide, zinc oxide, bis(1-hydroxy-1h-pyridine-2-thionato-o,s)copper
    Activity level / Ship types
    high speed vessels > 18 knots with high frequency
    Hull area / Comment
    all underwater parts of the hull
    Hersteller Jotun
    Anmerkung: Ist Ecoship von Antifouling-Shop
    Zuletzt geändert von ADMIN; 28.01.2007, 17:07.
