Gesetzgebung Schweiz
  • Gesetzgebung Schweiz
    Legislation
    Antifoulings of any type (biocidal and biocide free) may only be marketed in Switzerland if the manufacturer is in possession of a marketing permit. The department responsible for the issuing of permits is the Swiss Agency for the Environment, Forests, and Landscape, SAEFL (www.umwelt-schweiz.ch/buwal/eng). When requesting a permit for antifouling paints the name of the product, full composition, intended use and method of application must be supplied. The company submitting the application must be domiciled or have an agency in Switzerland (Ordinance relating to environmentally hazardous substances, 9 June 1986).
    As one part of the Lake Constance is Swiss territory, the Lake Constance Directive banning those antifouling biocides which may cause harmful and long-term effects on aquatic life is in force.
    There is an actual list of approved antifouling products 2005, provided by the BUWAL/OFEFP/UFAFP. For details see:
    List of Approved Antifouling Products 2005
    Bewilligte Antifoulings für die Schweiz
