Gesetzgebung Finnland
  • Gesetzgebung Finnland
    Legislation
    Antifouling products are chemicals used to control the growth and settlement of fouling organisms (microbes and higher forms of plant or animal species) on vessels, aquaculture equipment and other structures used in water.
    According to the amendment of the Chemicals Act (1198/1999), approval for antifouling products with either chemical or biological mode of action had to be applied for in Finland by the end of 2001. Thereafter only products for which applications had been made to the Finnish Environment Institute during 2001 or which have been approved according § 28 of the Chemicals Act may be placed on the Finnish market.
    An application for approval had to be submitted to the Finnish Environment Institute before January, 1, 2002 for any antifouling product that has been on the market in Finland or in some other EU Member State on May, 13, 2000 and which is intended to be placed on the market in Finland after January, 31, 2001. After the application has been submitted, supplying the Finnish market may continue until any other decision has been made by the Finnish Environment Institute.
    Since 1 January 2002 it has been prohibited to place on the Finnish market antifouling products for which an application for approval was not been submitted before 1 January 2002. Approval for these products may be applied for later, according to the procedures given in § 28 of the Chemicals Act.
    These transitional provisions are applicable during the 10-year transitional period (until 13 May 2010 at the latest), and in the case of a single product until a decision on the inclusion of the active substance(s) into an annex of the BPD has been made according to the Directive.
